sandynator
Last Thursday I got the New Corsair Spec 05 case delivered from Amazon.
Yesterday I shifted all components to it & found that there is no separate Front USB cable but just common USB 3 front with 2 flat cables joined together to single header.
In manual they have mentioned 2 separated wires but in actual there is one common wire I guess.
I cannot get the Front panel USB working as My Gigabyte H81SPH Rev 2 does not support Front USB 3 header.
Can any one clarify if they have skipped it in New version as mine is imported in september 2020
Please share the corsair customer care support for India as the sticker on the box is faded. I guess it could be deliberate attempt to wiping of few digits & alphabets of Corsair customer care support toll free number as well as email id.
Can I add some PCIE usb3 Card to get front panel USB's working?
