Help problem in xp
appu
Knowledge Nomad
I have win xp sp2.its was working fine till a few days but from yesterday i have a prob
a process in d xp by d name SPBBCSvc.exe has been eating up d system resourse
its least cpu usage is 70/85 % and its memory usage is around 89,680k
vmsize is 229,668
on max it can take more dan 100% of cpu 125,729k memory and 460,416k vmsize
coz if dis i cant work properly at all
my ram is 256 mb cpu p4 2,41Ghz
plz help me
koolbluez
Šupər♂ - 超人
Please Google first...
spbbcsvc.exe is a core component of the Symantec Internet security suite and assists in keeping your computer up to date from Internet bound viruses. This program is important for the stable and secure running of your computer and should not be terminated. It a Symantec Tamper Protection executable, like an intrusion detection process.
Click Here to Scan Your PC including spbbcsvc.exe to Detect any Security Threat
I'ld always say.. ditch Norton or Symantec Internet Security. U got free, better options. Lesser load on computers.
No much idea on Norton.. never used it. Hogs my system.
But... u can disable it or uninstall Norton as a whole. Install a new, updated antivirus & run the system scan. AVG and Avast r two free great antiviral packages. And use COMODO for Firewall... u'll b safe.
shantanu
i think you have a virus in your system..... try a antivirus and scan your system.. also end the process named SPBBCsv.exe
and go to run in start and type there MSCONFIG then go to startup tab and look for SPBBCsv.exe and uncheck the box in front of it...
T
thunderbird.117
Guest
Good that i do not use any of symantec products. Nod32 is the best :)
Arsenal_Gunners
Kaspersky Internet security is the best in paid products.If you want free-Avast is the best AV.Also use Spybot and windows defender with ANY antivirus.
appu
appu
Knowledge Nomad
ravi_9793 said:
ok./...than this may be a norton file.A file with same name is also there in norton...
I will suggest you do a online scan at www.bitdefender.com
well thnks for ur help
i have uninstalled norton now so could u advice any antivirus for my comp
i am using zone alarm for firewall so any suitable antivirus:-?
ravi_9793
TechTin.com
^^^^...well zone alarm is also good option.But I wont recommend u this.
Rather go for.......Kaspersky or NOD 32.
anandk
Distinguished Member
norton 2006 will make ur pc slow. sugst u use kis or zass instead. if u wanna convince urself, that ur pc is not infected, get ur hjt logfile auto-analysed at www.hijackthis.de.
c *www.auditmypc.com/process/spbbcsvc.asp too.
