Help : Pc Restart problem
kg_87
I have got problem with my PC.From past few weeks,whenever i run a Game my PC restarts automatically after few minutes.I get no error,no log report.
My PC configuration is :
Intel P4 3.0GHZ
Asus P5RD1-VM
512 DDR RAM
XFX Geforce 7600 GT
Thanks
kg :p
Ambar
aka. ViKiD?
immediately after the pc restarts turn it back on and goto the BIOS by pressing del..(maybe diff depending on ur mobo)...thre check ur processor temperature....it should be in a subsection called hardware monitoring....if its anywhere above 75 C then its a heating prob and u need to check ur airflow and cab fans....if its normal then check ur gfx card temp after turning on the pc and right click on desktop>settings>advanced>geforce 7600 gt>temp setting......it should not be more than 75 (atleast my friends dosent go beyond 75:D )...iff the prob is not here also then its most probably a failing PSU( do post the wattage)...
K
kg_87
Ambar said:
dood then its most probable a failing PSU or faulty ram....download memtest..frm
www.memtest.org and check if ram is to blame how old is ur PSU??:confused: :confused:
2 yrs old :(
Ambar
aka. ViKiD?
it maybe a PSU prob...but to be sure if u have another psu try using it...and do run the memtest prog!!
K
kg_87
Thanks
How to run memtest ? :-(
I ran the memtest program.it didn't find any errors.Can this problem be due to Windows ?
Ambar
aka. ViKiD?
ya maybe due to some faulty video drivers ....or direct x and does it happen with all the games ??....try the latest forceware drivers and directx 9c...also try changing the PSU...which is most likely to be the cause if not drivers and direct x....hope it helps:) :) :) :)
K
kg_87
I re installed Direct X and Video Drivers and still problem exists.
Can someone tell me the working of PSU in brief .How this problem is related to PSU ?
*forums.nvidia.com/lofiversion/index.php?t37898.html
:hmm:
sashijoseph
Doesn't it ever happen when you're not running games?
Would suggest first a format and fresh install of the os and drivers.If the problem still persists then start zeroing in on your hardware....psu,ram etc.
K
kg_87
No
ok Thanks :p
Liggy
Is actually a real word..
right click my computer go to properties click advance tab, settings button under startup&recovery uncheck check box that says automatic restart. this way you should get an error screen (everyones favorite BSOD) which should be more specific about the error. Google the error, or search microsofts knowledge base for the error. what r ur specs for your computer and what game is giving you the problems? are you running Norton (it is a resource hog), or any firewall/antivirus. does this game work online as well. it could be conflicting software, could be crapware(virus/trojan etc.) when was the last time you ran a full sys scan for threats. it could be Hardware related but usually is not the case.
