1. Hey Guest Did you know you can win an Honor 10 phone worth ₹33,000 and an additional ₹70,000 in paytm vouchers, just by replying to some threads and taking part in the discussions happening in the Honor Hub?
    What are you waiting for? Start commenting and start winning! Remember to read the instructions posted here.
    Dismiss Notice
[Help] Need best in-ear headphones for traveling below ₹2000 +/-
Discussion in 'Audio' started by TigerKing, Jun 8, 2018.
  1. TigerKing
    TigerKing Active Member
    Dec 24, 2016
    471
    50
    28
    Mumbai
    Can anyone help me out with finding best value for money headphones??
    Things I want..
    In-Ear wired headphones,
    Good Bass,
    Crystal Clear Sound,
    Better Noise cancellation,
    (Frequent traveling, Mumbai Local, Express etc etc)
    Tangle free wires or braided wires,
    Any other things to consider??
    Please do tell me..
    Budget is too tight.. ₹2000
    If headset is best in that range, then only I can go above ₹2000.
    Thank you.
    One of the mi fan suggested me this one..
    Mi In-Ear Headphones Pro HD - Mi India
    Is it good Bluetooth receiver?
    [Mi Bluetooth Audio Receiver]Product Info - Mi India
  2. OP
    TigerKing
    Dec 24, 2016
    471
    50
    28
    Mumbai
    Anyone???
  3. Enthusiast
    Enthusiast New Member
    May 21, 2018
    1
    2
    1
    I was in the same boat as you & went for soundmagic e10c.I was blown away by how good these sound considering the price. Easily miles better than any stock earphones(including apple earpods) i got a refurb unit. its good as new. considering your budget you can buy a new piece from Amazon or save and get a refurb unit for 1100ish on ebay.
    TigerKing and Nerevarine like this.
  4. Nerevarine
    Nerevarine Well-Known Member
    Feb 6, 2011
    5,921
    160
    63
    Pune
    To add to that, you can easily get a E10BT, if you game a lot, then stick with e10c.
    (e10BT has latency)
  5. Minion
    Minion Well-Known Member
    Oct 6, 2011
    3,635
    68
    48
    Bangalore
  6. quicky008
    quicky008 Well-Known Member
    Nov 27, 2007
    1,381
    29
    48
    Kolkata
    i have used the sony xb55 and was really satisfied with its audio output-it seemed well balanced with a decent mix of bass and treble.I used to have a boat 235 earphone earlier which sounded pretty awful-sometimes they sell in the 1000-ish price bracket on sites like amazon and should be totally avoided by the discerning buyer.
  7. OP
    TigerKing
    Dec 24, 2016
    471
    50
    28
    Mumbai
    I am willing to increase budget to ₹3000..
    soundmagic e10c
    https://www.amazon.in/Soundmagic-E10C-in-Ear-Earphones-Black/dp/B01H3F0SDI
    looks great with box contents..
    Best earphones Under Rs. 3,000
    as per this, which is suitable for traveling?
    RHA - S500 Universal
  8. Minion
    Oct 6, 2011
    3,635
    68
    48
    Bangalore
    Yes,these have better build quality than MA390 and sound quality is excellent
  9. OP
    TigerKing
    Dec 24, 2016
    471
    50
    28
    Mumbai
    ok.
    Buy Headphones & Earphones Online - Premium High End Headphones
    good site to buy? (heard of it but not purchased anything from there)
    watching movies, tv series compared to music..
    any other suggestions..
    confused between...
    1. RHA - S500 Universal - ₹2999
    2. RHA - MA390 Universal - ₹1999
    3. JAYS - a-JAYS One+ - ₹2999
    4. 1MORE - Single Driver - ₹2249
    5. https://www.headphonezone.in/collections/1more-headphones/products/1more-dual-driver - ₹3799
    anything else?
  10. Minion
    Oct 6, 2011
    3,635
    68
    48
    Bangalore
    Honestly don't have experience with any of these.read some reviews get what you like best.
    Headphonezone is good.
    TigerKing likes this.
Share This Page
