Help in buying USB hub
TigerKing
Buying USB hub.
Not decided 2.0 or 3.0?
Also with switches or without?
Detachable usb or fixed USB?
Budget not decided
Will be used mostly for usb light, gaming
Ascendant001
There are two types of usb hubs:
1.usual ones
2.external powered ones(they come with their own separate power adapter)
The one suggested above is an external powered one,these are costlier but also the recommended ones if you need to connect power hungry usb devices like portable hdd. For simple not-so-power-consuming usb devices like pen drives,kb,mouse etc the usual ones will suffice.
Get orico from aliexpress. I owned quantum, its a piece of shit, managed to fry itself. Build quality is terrible as well. Attached it to a double sided tape and when i tried to take it out, the entire thing separated.
