piyush2903
I am planning to Buy Sapphire Vapor-x Tri-x r9 280x graphics card and I have Corsair Carbide Spec -02 cabinet.
I am confused about will the graphics card fit in?
Also could anyone suggest me good graphics card in 25K max.
1. What is the intended use for this graphic card ? Gaming or workstation work? (Name few Games or applications are you going to run)
Ans: Complete Gaming (Heavy Graphics)
2. Which Power Supply do you have? (Be EXACT while naming the company and model)
Ans: Seasonic M12II EVO Edition 750W
3. What is your Max budget ?
Ans: 26K
4. Which Screen resolution will you game at (if applicable)?
Ans: 1080p
5. What are your current computer specifications ?
Ans: Motherboard - Gigabyte - GA990FX-UD3
RAM - 16GB 2133(G.Skill Ripjaw)
Processor - AMD FX-8350
Cabinet - Corsair Carbide Spec -02
Monitor - Asus VX238H - 23"
Ans: 26K
Ans: 1080p
