Friend need help for Building a gaming rig for 100K
imlokesh
Ans:I want a gaming pc.I like to play FPS games , the system should be able to run games like farcry 4 , Call of duty advanced warfare , GTA V etc. at highest graphic settings and will watch some movies .
Ans: My budget is 100K and can spend about 10K more.
3. Planning to overclock?
Ans:Yes.
Ans: Windows 7
Ans: 240GB SSD and 1 TB HDD
Ans:I want a 1080p LED monitor at least 23-24''.
Ans:I want to buy everything except speakers and headphones.
Ans:mid April 2015
Ans:Will be done by an assembler.
Ans:I am from New Delhi.I will prefer buying locally but can also buy online.
Ans: Naah.
Modified forum's 100k config
ProcessorIntel Xeon E3 1246 v320,000
CPU CoolerCooler Master Hyper TX3 EVO1,400
MotherboardASUS H97-PRO GAMER9,700
MemoryKingston HyperX Fury 1x8 GB4,500
Graphics CardZotac GTX 970 4 GB GDDR526,800
SSDSamsung 850 EVO 250GB8,500
Power SupplySeasonic S12II 620 W5,600
CabinetNZXT Phantom 4106,000
Internal StorageWD Blue 1 TB 7200 rpm3,500
Optical DriveAsus DRW 24B3ST DVD R/W1,000
MonitorAsus VK248H LED14,700
KeyboardCooler Master Devastator KB and Mouse Combo2,600
Mouse0
Total1,04,300
Overclocking the processor won't help in gaming, hence recommending Xeon here.
I
imlokesh
Mouse0
Total1,04,300
Some games are CPU dependent.Don't I need overclock my CPU for those games ?
you have recommended single 8 GB stick for RAM , Aren't 2 X 4 GB sticks better due to dual channel ?
sumonpathak
knocking on heavens door
Processor
Intel Core i5 4690K
17,475
CPU CoolerCooler Master 212x
2,900
MotherboardAsus Maximus VII Ranger16,600
Memory
Kingston HyperX Fury 2x4GB
4,964
Graphics Card
Zotac GTX 970 AMP Extreme
32,400
SSDKingston SSDNOW VNOW 240GB6,400
6,000
Monitor
Dell S2240L
7,950
Keyboard
Logitech K120
501
Mouse
Hyperion FURY 402
1,786
Total1,07,076
Since you want to overclock,changed a few things.
I
imlokesh
[MENTION=120490]sumonpathak[/MENTION] Thanks for replying
Shouldn't I choose i5 4690K for CPU as it is about the same price ? I am not a fan of kingston for their after sales service , I am thinking about going for intel 530 SSD.
Is there any difference in performance for ASUS Strix GTX970 and ZOTAC GTX970 ?
Also , I am not planning to overclock right away, is the stock CPU cooler enough if I want to run the CPU at stock speeds ?
sumonpathak
made a few more changes :)
also u can go with the stock..but its not very good.
I
imlokesh
I need a bigger monitor than 22'' , How about Dell S2340L ?
also, is there any difference between Corsair vengeance and Kingston HyperX Fury ?
sumonpathak
both has the same resolution :)
Also OC wise the kingston clocks better.
I
imlokesh
If I add dell2340L ~ 11.5K and Intel 830 240GB SSD ~ 10K .I go way over budget but I don't want to compromise on hardware.Are there any parts where I can save some bucks without losing on performance.
asciif00
@sumonpathak
ProcessorIntel Core i5 4690K
17,250
2,800
MotherboardMSI Z97 Guard-Pro
8,999
MemoryKingston HyperX Fury 8GBX1
4,278
26,805
SSDSamsung 850 Pro 256GB
11,733
5,900
6,000
Internal StorageSeagate 1 TB
3,531
964
MonitorDell E Series E2414H 24 Inches
10,119
KeyboardLogitech K120501
MouseHyperion FURY 4021,786
Total1,00,666
OP - bigger monitor, better SSD with 10 years warranty. Don't over spend on Motherboard, it is not worth it. Also please go through this review. MSI Z97 Guard-Pro is a solid Board. (Review)
There is a performance difference of less than 5 Percent between Zotac 970 and Zotac 970 AMP editon. (Review). Check the difference between ASUS ,MSI and Zotac.
If you have a Yes bank credit card you can get a 10 percent discount on the SSD.
I
imlokesh
17,250
2,800
8,999
4,278
26,805
11,733
5,900
6,000
3,531
964
10,119
Total1,00,666
Thanks for replying and info Mate!!
I am also thinking the same about Motherboard.I don't need SLI support .
you have changed the Dell E Series E2414H 24 Inches monitor ,this is a TN Panel monitor , I am not sure about buying a TN panel .I am more interested in buying an IPS panel.
And how about getting a corsair 650 W power supply instead of seasonic one ? everyone is suggesting seasonic power supply .
If you are considering corsair vs650 because of lower price, don't get it as it has less efficiency and is a basic model. You are better off with Antec VP650P or Corsair RM650 if Seasonic isn't preferred by you.
I
imlokesh
Ok ..will keep this in mind while buying stuff.
I want to buy a better keyboard than K120 ,but I have no idea to see how to differentiate between keyboards other than mechanical keyboards which are out of my budget. I want a backlit keyboard with palm-rest. can you please suggest any good one for about 3 K ?
sumonpathak
[MENTION=140678]iamlokesh[/MENTION] what exactly is your priority here?
getting a proper overclockable setup or getting a setup with big(size wise) display + shiny SSD?
if its the first then i suggest you stick with the Ranger since the alternative is not at all recommended for overclocking anything above an pentium unlocked processor since the voltage regulation circuitry is not upto the mark.(The VRM controller and components are sub par as is the case with all lower end MSI boards)
Also regarding the Dell E2414H display; its a TN panel based display whereas the S2240L is an IPS panel based display which will offer a better color reproduction/accuracy and better viewing angles(check this video : *youtu.be/BG7XNwbUYEM , the left one is IPS) i really don't see any reason of choosing the E2414H over the S2240L just for an inch which will not even result into a bigger screen estate(resolution wise since both are 1080P monitors).
As regards to the SSD, the 850 Pro will not help in any way getting in real world workloads like normal PC stuff or gaming.(Saying this after testing the 840 Pro,Kingston HyperX 3K,Adata SP 920).
So i would suggest to put ur investments mainly on the main parts that is CPU+Motherboard+GPU+Memory+PSU .
As regards to the power supply stay away form the VS or any low end lineup.
Mouse0
Total1,04,300
+100 to this.
asciif00
You can go for Antec VP650P - 4500 (Snapdeal)
or
Corsair CS650M - 6800 (Flipkart)
I
imlokesh
[MENTION=120490]sumonpathak[/MENTION] Thanks for your reply mate.
I am getting what you are saying.I am sure about buying a i5 4690K ,MSI GTX 970 OC edition , 2 X 4GB RAM and a good PSU .
Only thing I am unsure is the Motherboard.I will do a bit more research for the motherboard.
About the monitor , I want to purchase IPS panel monitors instead of TN panel for the same reasons as You told.
sumonpathak
if u want to OC, a good motherboard is a must.
Think of it as a chassis and engine of a car..unless its good u cannot race it.
