Firewire Problem.. Please help.. URGENT!
pranavrules2006
Hi. I recently bought a HP Pavillion dv2119 laptop. I have a camera which has only a 6 pin Firewire port for transmission of data, which looks like the picture given below. The laptop which i have bought, has a 4 pin firewire port [The smaller version of firewire] Now, i need to use the camera and in order to transfer the pictures, i need a firewire port and there is no other alternative. My laptop has a One ExpressCard/54 slot (also supports ExpressCard/34). So i searched the net for the card which has firewire ports and works on Expresscard slots.. I found this site: Firewire-1394 with this card: SIIG FireWire ExpressCard. Now the problem is that i dont have anyone living in the US so that i can order via them. Neither can i buy using a credit card since i dont have one..:( So can someone please tell me where i can get this card in Mumbai? I live in Mahim/Shivaji park area. If not this product, then can you suggest me some other available product which has the following requirements:
HP Pavillion dv2119
6 pin firewire cable [IEEE 1394a Firewire 400 Cable]
Please provide me with a dealer/retailer/distributor of the above mentioned card or any other alternative card with same functionality in Mumbai. Please reply soon as the firewire card is ABSOLUTELY necessary for me since i wont be able to carry out my work without the card. Please mail me if possible..
mail: pranav_s_2000@yahoo.com
Thanks for helping me..
Pranav
6 pin Firewire Cable
*img381.imageshack.us/img381/4918/firewire6pinyy8.jpg
SIIG Firewire Card (Which supports 6 pin Firewire cables):
*www.firewire-1394.com/images/siig-expresscard-firewire.jpg
shantanu
buddy you can get this in mumbai i am sure there is someone in the forum who might help.. i will also look for something will get back to you soon .. DONT WORRY ..
shantanu
ya i will surely just dont worry!!:p :cool:
__________
MAHAVIR ELECTRONICS
10/A Yamuna Bldg., Ground Floor, Opp. Police Stn.,Topiwala Lane, Lamington Road, Mumbai-400007.
try it here may be it could help
P
pranavrules2006
Thanks man.. I will go to lamington road and check it out today itself.. Thanks a million. You ROK!!:cool: ;) :D
__________
If possible, can you give me any other solutions as well? Such as any other card which is available in mumbai which supports the above requirements? I would love to have a option for this card.. thanks..
digiFriend
as your camera has 6 pin fire wire, and your lap top has 4 pin fire wire. you only need firewire cable which has 6 pin one end(large pin) and 4 pin (small pin) at other end. this cable come really cheap. if you cannot find, search for pci fire wire card. it cost around 175 rs and come with such fire wire cable.( leave pci card and use that cable.)
