Full Array LED without Local Dimming is worse than Edge LED
^^full led are being used in samsung EH series tvs which are budget leds tvs.
Full array led are much better than edge led tvs.You will not face problem like banding,clouding,flashing etc screen will be uniform.disadvantage is these are not slim like edge led.
@vikas33
Read this
LED TV - The Truth About LED Televisions
LED TVs compared: Local dimming, edge-lit, and full array - CNET Reviews
Nope. These cheap full array LEDs use lesser LEDs than EDGE LED models and as such have poor PQ. You can check the reviews on any website.
No..What these low cost Samsung LED TVs use is Direct LED which is no where near to the Edge LEDs. See the below links ->
Low-Cost Direct LED Backlights to Reduce Premium for LED-Backlit LCD TVs - DisplaySearch
What is a direct-lit LED LCD TV?
I am saying they may not have great picture quality of higher end edge lit model due to absence of local dimming but screen uniformity is much better in back lit models.you will see black in black scenes not gray.
See this
LED Backlighting vs. Edgelighting | Home Theater
You can see advantages of direct lit tvs over edge lit tv when playing a dark scene in both tvs.In tv world what you pay for is what you get.
One more thing i found is more contrast in led back lit model than old CCFL.
Sony is selling three types of led tvs they are EX series are edge lit models,HX series are dynamic edge lit models (having local dimming features),HX 925 uses full led with local dimming.
if you are saying direct lit led is a cheaper tech then why sony HX 925 is using it.
See this
In edge lit LED TVs, the backlight for the LCD screen is provided by LEDS arranged along the edge of the panel. In the full array LED versions, the LEDs are arranged along the whole background of the screen. There is indeed a difference in performance of Edge Lit LED TVs vis-a-vis Full Array LED TVs - mostly in terms of contrast levels and brightness. In full array models, the LEDs in individual segments can be dimmed to create higher contrast. In the same way, since the whole screen background is lit, the brightness is also better. For these two reasons, full array LED TVs are considered to impart a better quality. However, since the number of LEDs needed are many times higher, it invariably leads to significant cost increase - hence this type of TV is more expensive. At present, there are no full array LED TV models in India (of any brand). However, LG is soon expected to introduce LG LM9600 (sometime around Diwali) - this will definitely be the first Full Array LED TV in India.
Did you read my post ? Don't confuse Full Array backlighting WITHOUT Local Dimming and Full Array backlighting WITH Local Dimming. The new cheap Samsung/Sony sets with Direct LED do not have any local dimming so they do not really have great black levels, but yes the only positive is slightly better uniformity.
HX925 is a Full Array LED Local Dimming set, don't compare it with the cheap Full array sets. Full Array LED with Local Dimming is much more expensive to produce than even EDGE LED. Whereas the Direct LED without local dimming tech use less LEDs than Edge LED and are much cheaper.
