Cooler master elite 430 cabinet issue
webdesigncut
Hello friends..
I have been using cooler master elite 430 cabinet for last 6/7 years and today when i tried turn on the power the fans are getting on and then going off..although mother board light ..monitor light is on..so is it issye with power switch? Can it be replaced? Or time to get a new pc cabinet?...( budget around 4k)
If so do suggest a good pc cabinet with 5 fans as the present one had 2fans at top..1 at front..1 at side and 1 rear
I was checking antex gx202 ..how many fans it has ..is it good?
nac
Hello friends..
So you PC works? Just the cabinet fans aren't working?
webdesigncut
webdesigncut
Yes pc works..i just turned it on early morning.. and now the power switch not working? A year ago one of my hardware engineer said i have issues with power switch..cabinet fans are working but just for few seconds and the pc is not turning on
webdesigncut
webdesigncut
When power switch is turned on fans runs for few secs and then goes off and pc is not booting..although motherboard and monitor power light turns on
nac
You're contradicting yourself.
If PC fails to boot, then it's probably not the cabinet. If you think it's the cabinet switch, do a bench test.
Google if you haven't done bench test before. BTW, what's your PC configuration.
webdesigncut
webdesigncut
I just talked with hardware engineer..he told if your fan running once and shutting down..most probbably your psu or motherboard is short..in either case you have to replace the same
My specs
processor -Athlon 200GE(mdcomputers,has inbuilt graphics)
mothdrboard-Asus prime A320M-K--
smps corsair 550 watt
2*4gb 2400mhz corsair ram
My specs
This can be also faulty ram module, bad contact between motherboard and ram module ( due to corrosion / oxidation ), faulty bios ( try clearing CMOS ) ... anyway, do follow the open bench test process first.
