BSNL Modem issue/ISP issue? DSL light going off randomly
jkultimate
GAMING IS NOT A CRIME
Hi guys, 2 days back this issue started.
If I turn the modem on, all lights will come, and lock on... am able to browse net..but after using for 5 or 10 minutes, the dsl and internet light will go off, and dsl starts to blink again... then automatically reconnects... sometimes it won't.
What will be the problem..?
Could it be a faulty splitter/filter?
Or modem issue?
If it is modem issue, how is it working fine for some time?
what is average life span of a standard modem?
Mine is Utstarcom wifi modem.
Thanks in advance :)
ashs1
well, i'll be damned !! i am facing the same exact issue.. the constant disconnecting/reconnecting has been frustrating as i was planning on playing MMORPG ( winter holidays ) :-X
i've lodged a complaint on BSNL customer care last week..but there has been no response from them...
jkultimate
jkultimate
:( oh sad to hear :(
ya bro... me too Christmas holidays, planned a whole to download... but now :(
open modem settings page(192.168.1.1) & in status/device info page check both snr values are above 15 & both attn values below 50.some modems use non-standard (0.1dB) scale for these values so in that case divide values by 10 to get standard values.if these values are not within this range you will face issues.cause of this can be bad line,bad splitter,loose connection etc.
jkultimate
jkultimate
SNR values are lesser than 15, attn values are below 50
SNR Margin (dB):10.2 8.4
Attenuation (dB):34.0 19.3
Output Power (dBm):13.1 0.0
Attainable Rate (Kbps):11172 600
poor snr values result in frequent disconnections.check your telephone line for any cuts/joints/loose ends.also check dial tone in land line phone for any cracking/hissing sound.it is either line(most likely) or splitter.
nipunb
was also facing the same problem from past few days, lodged a complaint with bsnl and a technician came to check. Turned out, there were 3 joints, without any covering, in the telephone cable between the pole and my house. He told me that due to direct sunlight and mist in winters on the uncovered cable, the snr goes down and internet stops working. He just repaired the joints and covered them and my internet has been working perfectly all this week now.
jkultimate
jkultimate
Yeah, there is some kinda hissing noise kinda sound in phone... hmm Tomorrow I will try it with a new splitter..
thanks bro :)
Ho...my snr values are low... might be because of this.
thanks bro
RohanM
@op i dnt knw that ur issue is solved or not.
I was having same issue since last two days, called bsnl, they came & changed the whole wire..
later told that the wire was a small cut due to kite (patang dor) lol..
now no issue.. :)
