Big Cabinet with 4 Front USB
singh_dd93
Hi Guys,
I am finally building a hackintosh for which I posted a thread earlier. I had to change few item on recommendations from hackintosh forums.
Here is the list
CPU: Intel Core i7-4790 3.6GHz 22900
Motherboard: Gigabyte GA-H97-D3H 8400
Memory: Kingston HyperX Fury Blue 16GB (2 x 8GB) DDR3-1866 6500
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive 5145
Storage: Western Digital Caviar Green 1TB 3.5" 4000
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case 7600
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified 5000
Wifi: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 2500
Now the thing is I am looking for alternatives to Phantom 410.
Main needs:
A big cabinet (I like it )
Should have at least 4 front USB
Should support 240/280 mm top exhaust. I will be using H100/H110 soon
I am trying to keep this under 6.5k
dekaron
Very few cases support H110, and 4 front USB is rare , it becomes even more narrow in the budget
*pcpartpicker.com/parts/case/?compatible_with=corsair-cpu-cooler-h110#sort=a8&page=1
S
singh_dd93
So I guess I should go with the selected one.
BTW Guys I need some buying advice on Buying from Nehru Place.
Kindly check my thread in Shopping Category : *www.digit.in/forum/shopping/195044-buying-nehru-place.html
