Basic office work CPU for less than 15K.
BhargavJ
The CPU in my office has gone dead, and the technician whom we usually calls says the MB is dead, and he'll give a new Intel CPU for 17K; another guy says he'll give one for 13K.
I need only a CPU, as we already have a monitor as well as keyboard and mouse.
Use: only office work; typing in MS Word; Firefox; not gaming or any other intensive work.
A CPU === MB + Proc + Power Unit + RAM + Case + DVD burner. The old HDD (160 GB) is still working and still has a lot of GBs left. It is the older kind, if I remember correctly, where you have a lots-of-pins data cable, not the smaller SATA cable. But I'll confirm and tell tomorrow.
Budget: Below Rs. 15K. The cheaper the better.
Processor: Intel or AMD.
RAM: Maybe 2 GB will suffice, but 4 GB will be better.
OS: Office will decide. The old one which has stopped working had Win XP.
OCing: No.
Will be assembed by local guy.
Live in Gandhinagar, Gujarat.
If the current HDD won't work with the newer CPU, please suggest a new one.
Thanks.
Tech_Wiz
CPU means processor only & fill this first *www.digit.in/forum/pc-components-c...new-pc-help-answer-these-questions-first.html
B
BhargavJ
Sorry, by CPU, I meant the whole "dabba" - motherboard, processor, RAM, etc, not the processor alone. I've already answered the questions according the format.
adityak469
Training To Beat Goku
Pentium G 3220 ~ 3.2k
Gigabyte GA-H81M-S1 ~ 3.5k
Corsair Value Select 1600 MHz 4 GB ~ 2.5k
Local Cabby with SPU ~ 1k
Asus ODD ~ 1k
WD Blue 500 GB ~ 3k
IMO get a second hand 320GB HDD ~ 1k or a 160GB ~ .5k
