Rockstar11
i am searching good Full HD led 3d monitor at 15k budget.
how is LG Cinema 3D Monitor D2342P?
reply???
reply???
reply???
Here is a review on the Cinema 3D monitor you mentioned: LG Cinema 3D D2342P Review | Monitors | CNET UK
The reviews seem to be pretty good. The only thing to note is that while viewing in 3D, the viewing angles are a bit limited. Otherwise, it is a great monitor. With its extensive color control options, I'm sure you will be able to find some good calibration settings for the best picture possible.
LG WRman Sherlock, out!
reply pls
Acer Touch and 3D monitor
no one use 3D monitor?![]()
whats the price of 3D TV???? can i use as pc monitor also?Unfortunately, 3D monitors have not really picked up the way 3D TVs have. I'm not entirely sure why, but I do believe that playing PC games in 3D is terribly underrated. Hopefully gaming in 3D will pick up in the future, but as of now, not many people know about it. Your best bet at this point would probably be to do some research on your own, looking for reviews from both well known tech sites and user reviews.
One of the cheaper 3D TVs available is probably the 32LM6200. It costs 41,800 Rs. on Flipkart, which is much more expensive than your original budget of 15,000 Rs. However, at the same time, this TV is much more functional than any monitor you will find. You can also use this as a 3D monitor, as you simply need to connect your computer to it via HDMI. Then you will have set the TV to "Game mode" to reduce the amount of input lag. However, I will warn you that while input lag from consoles to a 3D TV is negligible, for some reason, sometimes there is a bit of input lag when going from PC to 3D TV. I am not saying that the LM6200 definitely has it; I am only saying that it is possible you may experience some input lag. If you can, try bringing a laptop to a showroom to test it out for yourself to see if the input lag is acceptable.
thanks
i think there is no more choice.
i have to go for LG Cinema 3D Monitor, D2342P
Though you have discussed on various aspects of 3D monitor and TV above; so I just want to add couple of points ahead – like if you have to have a 3d monitor only (may be because of budget) then undoubtedly LG D2342P 3d monitor is best in class; since it’s using FPR 3D technology which is widely used 3D technology by many gigantic manufacturers (Panasonic, Vizio, LG and Toshiba) in their 3d TVs which means there is no sense of worrying about 3d results.Asus VG VG23AH 23-Inch Screen LED-lit 3D Monitor
its IPS panel monitor
Furthermore, if you can manage then I would suggest you to look for the 3d model which LGWRSherlock have suggested LM6200. These days almost all retailer are giving EMI options, so search a bit and set your mind if you can afford it; otherwise stop comparing any other model and stick with D2342P.
