1440p 144Hz Monitor and Monitor/Laptop Mount
RCuber
The Mighty Unkel!!!
Need an additional monitor for coding/gaming. I already have a BenQ XL2411Z (1080p 144Hz, DVI and HDMI) connected to my PC. Need a new monitor to go with my HP Omen Laptop where I do most of my work. My Older monitor has limited connectivity so I can connect only with HDMI with the laptop (60Hz only).
Plan is to buy a desk mount and place the monitor and laptop on it and connect it via DP and my older monitor will be directly connected to my PC (DVI) and stay standalone unless I can get a dual monitor with laptop mount, or buy a dual monitor mount and a separate laptop mount.
1. Budget?
30K Total.
2. Display type and size?
24" or 27" 1440p 144Hz.
3. What will the TV/monitor be used for primarily?
70% Coding 30% Gaming
4. Types and number of ports required?
Minimum Two Display Ports.
5. Preferred choice of brand?
Not any in particular
Not shortlisted
