What is Tj Max? And why are my temps fluctuating so much?
Discussion in 'Hardware Q&A' started by Nipun, Dec 11, 2011.
  1. Nipun
    Nipun Whompy Whomperson
    Mar 10, 2011
    1,514
    19
    0
    New Delhi
    Hello people!
    First, please tell me what is Tj. Max (not the clothing store! :p)
    Second, the temperature in Core Temp 0.99.8 is fluctuating too much. The temperature went from 50 C to 71(never went above 64 before), then returned to 60 and again touched 71 2 times. All this happened pretty fast, within a minute the temperature fell from 71 to 60 and went to 71 in 2 more minutes.
    The Tj Max in core temp is shown as 70, and when temperature crossed it, the core temp icon in taskbar began to blink. I guess this was some kind of warning.
    The running programs at that time were:
    Google Chrome(5-6tabs)
    Steam, Steam Backup
    GTalk
    MTS
    Skype
    Core Temp
    + Other background processes
    I closed almost all the programs immediately and temperature came down to 45-50, but I am a bit worried.
  2. The Sorcerer
    The Sorcerer oh wow...Xenforo!!!
    May 24, 2008
    2,402
    7
    38
    ..and your system configuration is?????
    There's a clothing store called TJ Max? :|
  3. OP
    Nipun
    Mar 10, 2011
    1,514
    19
    0
    New Delhi
    Yes, its Tj Maxx (google it).
    Phenom II x4 840 @ 3.2GHz
    MSI E35-880GM
    Ripjaws X 4GB
    Sapphire HD 6850
    CM GX 450W
    PS: Now temps are fine at 35C... :|
  4. vickybat
    vickybat I am the night...I am...
    Aug 16, 2008
    5,652
    31
    0
    Gotham City
    Found it from here.
  5. OP
    Nipun
    Mar 10, 2011
    1,514
    19
    0
    New Delhi
    Now CPU temperature reaches 85-95 C while playing Dirt 3 or GTA 4... :(
    Please help.
  6. whitestar_999
    whitestar_999 Super Moderator Staff Member
    Nov 7, 2011
    5,688
    58
    48
    NCR
    check your cpu cooling solution & TIM.if overclocking revert back to stock speed.according to some online sources TJMax value is set different for different processors & usually 98-100C.when core temp reaches this TJMax thermal throttling start taking place.thermal shutdown temp is usually TJMax+25C.at this temp cpu shuts down.
    i7 2600k tjmax - Overclockers Forums
Share This Page
