Hello Everyone!!!
Guys I am facing a very strange problem in our LAN. There is a Wire Providing connecting between two switches.
Problem is that it works fine when first time i connect wire on both end but after two or three days there was no signal of data transfer and there was no connectivity between the computers. I put the plug in different slots but still problem was same.
Then i cut from one end and put another connector onthe cable. After that again it worked fine for 2-9 days. Then again it stopped. Again i did same thing as i did before.
So every time i m doing this. Can u guys please suggest me what should i do to get rid of this problem?
Thanks
Thanks
