nileshgr
This nonsense smart removed sudo while i was removing vim. I am not able to use apt, yum, smart now. What do i do? Even rpm doesn't work to install sudo. I tried compiling the source using make, it also gives error. Now i shud shutdown my pc or not???? Please answer as fast as possible!!!!!
