Setting up WiFi for a huge home. (10,000 sqft)
neo_natasha
Hello guys,
I got a new request, my friend needs to setup a wireless network for his house. Problem is it is HUGE. And he expects to get a fair signal in all rooms / halls / places.
(Now if you are wondering this is another imaginary fake request its not)
Budget is not a problem. All rooms have proper connections (ie telephone wires / cables placed in required places)
The solution I suggested to him was to get a TP Link 1043ND (which is the one I have and which too was suggested by you guys) as I found its signal to be quite strong. (DDWRT is slightly out the question as I cannot go an personally set it up for him). And to add more 1043 ND as access points in each room. Or do you guys have a better answer.
Few points
- The house is huge
- Lots of concrete walls inbetween
- You can expect a few other wireless devices in the house
- Money is not an issue, but would like to keep it to a nominal value.
- 10,000 sqft has to be covered (ground floor alone). Not sure if it has a first floor will check and update.
Thanks,
Santhosh
Top
