koolbluez
Šupər♂ - 超人
This is a $hit problem i got here.... suddenly my lappie goes into a frenzy of typing "-" whereever possible... like the key has stuck.... but i checked out the key.. no problem there afaik. Sometimes "+" is typed. Because of that i'm not able to type.. not even put my cursor in a data-entry field.. it even goes on when i use anything else.. like my browser view text size decreases (Ctrl+-). Also when i restart.. it continues.. making my lappie beeeeeeeeeeeeeppppp... as the key is still pressed i suppose.
Sometimes it stops again.. like now.. dunno when it'll come back.
Noticed that when i disconnected my docking station expansion port it stopped. My mouse was wirelessly connected to my lappie via the docking station. But prob didn't return back immediately after i plugged it in again.
It it a sw/virus issue or hardware issue? My AVG & Norton showed no probs!
I rechecked the -/+ keys. Another press (or some repeated presses) on the key would help if it was stuck. Nuthin of that sort worked.
Urgent help needed. Desperate. Any1 got that prob... not a sticky key prob i think. Please help.
If this helps... HP dv9311TX lappie with Vista Ultimate & HP 3000 series docking station.
