Need help to built a gaming machine in 30k!
hattichya
Joined
Jan 29, 2012
Messages
3
A: It should play upcoming GTA 5, CoD ghosts, BF 4, NFS series at higher settings.
Application would be limited to MS excel, MS office.
Ans: 30K
3. Planning to overclock?
Ans:No
Ans: Windows 7 (32 bit)
Ans: Presently having 80 GB IDE and 250 GB SATA HDD. No HDD suggestions required.
Ans: I have a 15 inch CRT monitor. Not wishing to update till it gets down. Its been running since 2003! ;)
Ans: 1. Cabinet, 2. Mouse, 3. Keyboard, 4. Corsair VS550 PSU, 5. Sony DVD RW, 6. HDD's, 7. Monitor.
Ans: In a week or two.
Ans: Assemble it by myself.
Ans: Mumbai, Prefer buying locally only. i.e Lamington rd.
Ans: I have presently Gigabyte mobo (GA MA 78gm s2h), AMD 4200+ procey, 3 gb ddr2 RAM(1gb transcend + 2gb kingston) and rest as said above.
I would be grateful if you provide suggestions in which mobo, procey & RAM are kept as it is. RAM can be increased, still have two slots empty. This is only applicable if machine would be future proof or else
Plz suggest replacement of mobo, procey and ram as well.
Thanks in advance! :)
Hattichya
rijinpk1
Joined
Apr 6, 2012
Messages
5,578
which cabinet do you have?
here goes my suggestion
fx 6300 - 7.2k
Gigabyte GA-970A-DS3 - 5.5k
gskil RipjawsX 4 gb at 1600Mhz- 2.5k
asus hd 7790- 10k
dell in2030 - 6k
i suggest to upgrade your monitor. your current monitor is ancient. if you can upgrade your monitor after a month or two ,then get hd 7870 at 16k.
also install 64 bit os not 32 bit.
Cilus
laborare est orare
Joined
Mar 6, 2009
Messages
7,302
For motherboard, OP can also look for ECS A-970M-A-DELUXE motherboard, currently available at 5.58K in theitwares.com. It has positive reviews and build quality (VRM, solid capacitor etc) wise, it is also superior to the above mentioned Gigabyte Motherboard.
H
hattichya
Joined
Jan 29, 2012
Messages
3
fx 6300 - 7.2k
asus hd 7790- 10k
dell in2030 - 6k
I don't know man :p Its local thats why bought a decent psu i.e corsair vs550. If you are asking for cooling i may get some fan attached by myself.
For gpu do you have any other brand than asus. The dealer here sucks. I have a bad experience here. So i avoid asus.
In addition would i be able to play above game in ultra high settings?!
Thanks for helping!
Top
