Need for speed pro street help
mikeydavies
Hi there all! i'm just wondering if any of you can help me, I'm getting a pc setup this week consisting of athalon 64 3200+ CPU on a asrock K8NF6G mobo wich has Nvidia geforce 6100/nforce 405 chipset and 1gig of ram what I want to know is has anybody tried and run NFSPS with this chipset and if so how well it ran. I've read the NFO for the demo version and it says Nvidia Geforce 6200 and upwards but I just wonder If it maybe compatible with what I have but to lower the specs of the game itself! Any help on this matter would be greatly appreciated.
Thanks in advance
M
mikeydavies
Thanks for letting me know mate,I'm getting my new system this week, thought it was about time to update my (very) old 633 system. I'm gonna overclock as much as possible on my new system anyways so hopefully that should help a little also! at least i know now that the game will run at least on min specs.
Ethan_Hunt
It will work but this game is a bit higher shader usage compared to previous 2 versions.Hence it would be best to turn of all the effects & run it at low resolution.Though the game itself if simply not worth it.;)
Top
