Q: What is your budget?
40K-45K excluding the Monitor. Separate Budget For Monitor atleast 20 Inches- Rs 10-12K
Q: What is your existing hardware configuration (component name - component brand and model)
I do not own any Desktop . I own a Laptop-HP DV5 1126ee
Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
Need suggestion regarding every component need to run a PC .
Processor
Motherboard
Memory/RAM
Storage- 500 GB sufficient. Since i have 2TB external Hard Drive
Power Supply
Cabinet
Graphic Cards
Coolers
Wireless Keyboard
Wireless Mouse
It will be my first Desktop PC.
If you guys are suggesting Intel , then i want Sandy bridge/ 2nd gen processors. i5 or i7 .
Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component?
Yes, will upgrade the system if need be in next 2-3 Years
It should be future proof.
Q: Where will you buy this hardware? (Online/City)
New Delhi- Nehru Place- SMC International or Computer Empire or Cost to cost,. or another recommended by you guys. Would like to buy all the components from one shop.
Open to online purchase, preferably Indian Website.
Q: What is your intended use for this PC/hardware
Gaming
Browsing
Desktop Processing
HTPC
Download rig, 24x7 operation
Watching HD movies
Office Use
Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
Just want to go for the best.
Do not want to buy Asus product as I heard the after sales service in India is pathetic
Q: If you will be playing games then which type of games will you be playing?
COD 4 ,FIFA,CRYSIS, NFS at medium to high settings
Q: What is your preferred monitor resolution for gaming and normal usage
Gaming - 1280x728 ,1600x900, 1920x1080
Desktop - 1920x1080, 1440x900
Q: Are you looking to overclock?
Not Necessarily.
Q: Which operating system do you intend to use with this configuration?
Windows 7 32/64 bit
(Additional) priority list:
1. Future proof (2-3 yrs)
2. The CPU must be able to have slot for 2 monitors. I will attach two monitors to this desktop.
3. Good screen
4. Need atleast 8 USB ports- Need to connect a printer, scanner,keyboard,mouse + Need atleast 3 free USB slots for other devices
5. Need a Wifi- Card for the recommended Desktop- Can buy separate Wifi Cards for the same. As majority of the time i will be connected to Internet via wifi
6. Must be upgradable
Looking forward to your suggestions, thanks.
Processor
Motherboard
Memory/RAM
Power Supply
Cabinet
Graphic Cards
Coolers
Wireless Keyboard
Wireless Mouse
Gaming
Browsing
Desktop Processing
HTPC
Watching HD movies
Office Use
Not Necessarily.
Windows 7 32/64 bit
3. Good screen
