Need advice for a buget level phone
billubakra
Hello Friends,
I have zeroed down two handsets for a budget of 14k. Since there is no discount for Moto G4 Plus, I don't think that I will be going for it.
Samsung Galaxy J5 (2016) vs. Motorola Moto G4 vs. Motorola Moto G4 Plus - GSMArena.com
Sammy Pros-
Super Amoled
Great UI
Customizable
Cons-
No Nougat update I suppose
Low processor as compared to Moto
No version of Corning Gorilla Glass mentioned anywhere
Production is stopped by Sammy AFAIK
Less Memory as compared to Moto
Price-11900/-
Moto Pros-
Octa processor
Full HD
Higher PPI
Cons-
IPS Display
No front flash LED
No OTG
Price- 10499(16gb), 11999(32gb)
I want to give Moto a try but the biggest things stopping me are IPS display and no OTG option. Moreover I have never used any Android device without a Samsung Touchwiz, which I personally think is cool, no offence to anyone. Any help?
Thanks
[MENTION=105611]bssunilreddy[/MENTION] [MENTION=145143]SaiyanGoku[/MENTION]
Waiting for your valuable advice brothers. Can't increase the budget, this is intended to be a gift for someone. This phone will be used to check mails, whatsapp, video calling and to play few games.
arko1983
u can check this.
Motorola Moto G4 Plus vs Motorola Moto M vs Samsung Galaxy J5 (2016) vs Motorola Moto G4 | Smartpri
if u have budget go for motorola m if not g4 plus.dont buy samsung if ur in a budget.
Minion
I will suggest these
LeEco Le2 X526 (Rose Gold): Amazon.in: Electronic
Lenovo Zuk Z1 Price: Buy Lenovo Zuk Z1 Space Grey Online at Best Price in India – Amazon.in
Choose anyone according to your requirement.
B
billubakra
u can check this.
Why not J5 bro? And I have budget only for G4, is it any good? I mean I am skeptical about IPS screen and it has no otg :(
leEco a big no. No service centre of Lenovo in my city :(
If you want a good samsung phone, skip all except the flagships.
Go with either Moto G4+, Moto M or Zuk Z2 if budget allows.
Redmi Note 3 is a good option if you just want to flash a custom rom. MIUI is crap IMO.
Dont ever go with Redmi Note 3 as RMA is a problem and there is no upgrade path to Nougat 7.0
Yess Skip all samdung phones in budget variants.
Its flagships are some of the best with regard to specifications.
Go with Lenovo K6 Note,Lenovo K6 Power, Lenovo K6, Moto G4 Plus, Moto M, Lenovo Z2 Plus, Moto Z Play if budget permits.
All the above phones are best in their budget categories with brilliant specs.
Moto M & Lenovo Z2 Plus use DDR4 memory for RAM.
Sent from my ASUS_T00K using Tapatalk
B
billubakra
Good luck finding a good phone within 15k. Moto G4 doesn't have good camera or processor like G4 plus actually moto G4 plus processor is not great.
Moto M should be fine for this....This phone will be used to check mails, whatsapp, video calling and to play few games....
armi
I own moto g4 plus. The phone works great since 6 months. Iam happy for it.
But a minor issue is that the phone randomly heats up on its own especially while browsing or after wifi tethering. While on the heating up duration the battery drain faster.
I suggest u not to choose this model.
Also the Chinese xiomi phones does not deserve its purpose. U can't rely on xiomi phones for long run.
Cheers.... Hope u find something else wisely.
Sent from my Moto G (4) using Tapatalk
armi
Hello Friends,
Sammy Pros-
Super Amoled
Great UI
Customizable
Cons-
Price-11900/-
Moto Pros-
Octa processor
Full HD
Higher PPI
Cons-
IPS Display
No front flash LED
No OTG
Thanks
I am a moto g4plus 32gb version user for the last 6months and I added 32gb microsd card. Some feedback on this phone.
It is a good phone with great performance and otg support as well. There are some apps in play store to make it explore my 32gb usb flash drive.
Cons are the phone heatsup randomly while browsing or tethering internet. And the camera gets delay while on hdr mode between snaps.
My feedback may help someone reading this...
Cheers..
Top
