1. What is the purpose of the computer?
A: Gaming, HD Movies, surfing
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes
3. What is your MAX budget?
A: 30,000
4. Planning to overclock?
A: No
5. Which OS are you planning to use?
A: Windows 7
6. How much hard drive space is needed?
A: The More the Better, at-least 2TB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: I already have a Samsung 40 inches LCD TV. want to use this for High resolution gaming and movies. THIS IS MY MAIN requirement, I do not need any alternatives for this.
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)
A: 5
A: will be done by assembler
10. When are you planning to buy the system?
A: October End, 2011
11. Are you one of the types looking out for "future proof" configurations?
A: Not really, but at-least 2 years future proof
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.
A: Monitor, as i already have a 40 Inch LCD
13. Which city do you live in and are you open to buying from shops from other city/states?
A: Chennai, i prefer to shop in local
14. Mention any other points if deemed necessary
A: My Main Requirement is that, i need a rig, which can run in my 40 inch samsung LCD with out any hazels. Need the Games and Movies to play perfectly in that TV. This is the only main criteria
I am not a techi person, so could not be able to answer anymore indepth technical question, all i need is a CPU which i can plug in to my 40 inch LCD and play high resolution games along with Hi Res movies
Help Please
A: Yes
A: 30,000
A: No
A: Windows 7
A: 5
Help Please
