HI I have windows xp sp2 intel 845glly destop board samsung 753s monitor .
I have a problem with Turbo C 2.0 and 3.0, whenever i use it on fullscreen I am not able to return back to my desktop the monitor goes blank,
when i quit turbo c the same thing happens
while usin turbo c in fullscreen i cant return to desktop using any shotcut to windows , the thing is turbo c gets minimized but i see no desktop just blank screen i restart the computer pressing the windows button on keyboard then 'u' then 'r' which means desktop is there but screen is blank
I tried formating primary & reinstalling winxp to no avail
this was not so earlier but i dont remember if the problem started exactly afer i installed sp2 the first time cause the problem persists even with out sp2 sp1 or any software installed on just raw windows xp
I dont use 98
May be my dos shell is corupt i dont know
Is there any fix to this , cause i do have borland c++ builder but i want to do graphics programs on TC which run on full screen
i start turbo c in windowed mode then when the graphics program is compiled it does not run in windoed mode but in fullscreen mode
I dont use 98
