Hello Guys,
Please help me out here cause i've a really bad problem wid my system....Whenever i shutdown the system, it takes a very long time to do so,sometimes 10 mins or more...otherwise not at all.I get a warning that states that a process called "cApp" is running and that i should shut it down..So each time I end up cutting off the power supply and later getting a message at Startup saying that my system was not shutdown properly the last time, and that I should run Scandisk on some of my drives.Is it because of a virus?But i cant seem to remember any particular download afterwhich i started having this problem.
I also wanted to know how to maintain my system properly.Please keep in mind that...
I have Norton Antivirus : but it takes a ridiculously long time to update the virus definitions on a connection such as the one I use...I regularly run full system scans and Norton usually returns some spyware on my system which it is not able to handle.So i end up putting it in quarantine.Is that the right solution?
I have Norton Internet Security : but i was told that it slows down the internet connection even more cause it scans every file that comes into my system.Is this true?
I have AdAware SE Personal : It updates fast enough but everytime I run a full system scan, it returns all kinds of spyware and dataminers and adwares and what not...funnily, it is quite unable to fix most of this.I end up deleting what i can and quarantine the rest.Again..is that the right solution?
I have Enigma Firewall : It is enabled whenever I am online.
Other than all this, I regularly defrag and run 'chkdsk' on all my drives to keep my system in the best shape I can. So its quite disheartening when my system still gives me trouble.Should I use any other tool(s) to Diagnose,Rectify errors and maintain my system? All the software i've
mentioned above are either pirated ones or freeware.Does that make a difference?I'm ready to get the original software if it really makes a difference...
I would also like to update my OS which is a WinXP Proffesional.Doing it online would be impractical as the connection is slow.Should I just apply the SP2 and other patches that i get in the DVD's which Digit provides.I havent applied any kind of patch to my OS at any point of time at all. If at all I do...How do I know that my OS is updated?
Please Help!!!
System Specifications:-
Intel Pentium 4,2.8Ghz
80 GB HDD
512 MB RAM
WinXP Proffesional OS
Any more Info that u might require....i'll be more than happy to provide...Thank u!
Please Help!!!
80 GB HDD
512 MB RAM
