hi everyone
i have a pc that i asembled about an yr. ago with the following config:
Asus M4A87TD USB3
AMD Phenom X6 1050T
MSi n480GTX GPU
Coolermaster GX650 psu
Gskill trident 2x2GB 1600 Hz
WD Caviar balck 1tb + caviar green 1tb
for the first 6 months there was no prob. after that the d"display driver stopped responding" errors started but were not that frequent.
then it became way to much n since my motherboard has been replaced twice. now, I think my psu is done for as the core unlock light that glows whenever the power is connected too doesn't glow and the system has stopped running totally.
also a lot of time my system becomes normal when the display driver STOPS responding while other times it just gets stuck...
the display does out... no restarts n no recovery either.
at first i though it was just coincidence but my system has started having lot of problems recently.
please i need some serious help....
wtf is wrong.. is it the config....
Asus M4A87TD USB3
AMD Phenom X6 1050T
MSi n480GTX GPU
