Serious Problem Need help (EXPLORER)
max_demon
IM AS MAD AS HELL!!
Everytime i open a drive , say C:, D: ANY DRIVE . it opens 'Open with' instead of opeaning . everytime i have to Rt click to open:mad::mad::mad::mad::mad:
Lucky_star
Still Shining!
Search for any hidden autorun.inf or autorun.ini files in the the drives and delete it. Before that uncheck the hide protected operating system files from the Folder Options->View menu
Ramakrishnan
The Researcher
Your solution should be in the folder options. Go there and see what is default action. If it is "open with" change it to open. Or simply click the button "set everything to defaults".
K
khattam_
Guest
This is some virus problem....
I suspect Ravmon E... Remove it with some good latest AV...
Vishal Gupta
Microsoft MVP
Also try this. Open regedit and goto:
Code:
HKEY_CLASSES_ROOT\Drive\shell
HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers
and make sure, that these keys don't contain any suspicious item.
