Resource Hacker Creating Problem........Plz Help!!!!!
krishnandu.sarkar
Simply a DIGITian
Hey frndz..........I tried those "Hack System Properties Dialog Box" and "Transform XP without customization pack" tricks given on VISHAL GUPTA's site www.askvg.com.
But the problem is whenever i save those dll/cpl files after editing with RESOURCE HACKER it gets saved but nothing gets changed, I mean nothing takes effect. A "_original" file gets created...........I deleted that too...........but nothing happens.
I tried this 100 of times but as usual no result..........After editing when I save those files and delete that "_original"...........I reopened that file again..........but surprisingly it's in its original form...........nothing of my edits are there!!!!!!!
I too patched my Windows with "Windows File Protection System" given on that site and Cracked my file protection but nothing happend.............What could be the problem???
Plzzzzzzzz Plzzzzzzzz Plzzzzzzzz Help!!!!!!!!!!!!!!!
Thanks in advance..........
New
If you are using dual OS, just use resource hacker in the first os to hack second's os..
Like using resource hacker in vista to hack xp..This works 2000%:)
Ecko
Wandering In Tecno Land
Dude Copy the file u wanna change to another place
Then make the changes u want & then replace it using replacer
So no probs
BTW : Always keep a backup copy of original files
Take a look at mine
*i36.tinypic.com/al5duv.jpg
krishnandu.sarkar
krishnandu.sarkar
Simply a DIGITian
Thanx a lot buddy.............U really helped me a lot............Hey I have 1 more ques.........How can I align those bmp's to left or right??????????
Ecko
To Align U have to look at the coordinate locations carefully*files.myopera.com/Tamil/Smilies/Happy.gif
Look at this image
To align something equally just make sure you have them equal
Just try out & you'll know how to change
*i33.tinypic.com/2na18vl.jpg
Vishal Gupta
Microsoft MVP
Or just select the resource (i.e. image) in dialog box and move it using arrow keys to your desired location. Once you have done, click on "Compile Script" button.
krishnandu.sarkar
krishnandu.sarkar
Simply a DIGITian
Hey vishal.............lotz of thanx...............ur all posts helps me a step forwarding 2 bcome a geek...............thanx again...............
Aftrall I found the problem...............the problem was with "_original" file. I used the "Unlocker" given there 2 ged rid of this prob.............
