Hello all,
I would like to explain the scenario first before posting the question:
I have an xfx 8600gt graphics card, which had blown capacitors some months back. I replaced those with electrolytic capacitors of same rating, and started playing some games. After a week or so, my SMPS blew off and rendered my USB mouse and PS2 keyboard useless. I replaced the SMPS, and started playing again with this GFX card installed. Now, there was some power fluctuation automatically(thorugh SMPS i suppose), and the Realtek Audio manager was popping up "device is plugged" and "device is unplugged" randomly. I restarted the PC, and after that my audio jacks are not getting detected. I tried to do the following:
1) Uninstall and Reinstall Realtek drivers ( done with different versions)
2) Tried with different BIOS settings
3) Tried re-installing Windows 7
4) Checked for sound devices under Device Manager
I am using Windows 7, and I suspect that those capacitors were the problem of bad keyboard, smps and mouse. But now, my audio jacks are also not working (I can see in volume mixer that sound is being played, but cant listen to the music) I also checked the speakers just to be sure if they are OK.
What does this indicate? Does this mean that my Audio Jacks are damaged? Is there any way I can get them back to work? What could be the reason of Audio Jacks getting damaged?
Thanks.
Thanks.
