Problem with Monitor
digik
My monitor is widescreen TFT LCD. It displays all the pictures from my digicam squeezed vertically. Can anybody help?
Cool Buddy
What is the native resolution of the monitor? if you don't know then search on the internet using the model number
most probably you have set the wrong resolution. Try changing the resolution from display properties, settings tab in XP
sonali321
A LCD monitors viewing angle is the horizontal and vertical viewing angle at which at which LCD screen is fully visible.
source:askthecomputertech.com/lcd-monitor-buying-tips.html
D
digik
Native resolution 1600x800 is not availbable in the settings of Win 7. Aspect ratio is already 16:9.
Sid_gamer
Team Digit
If you can't change your resolution then try Uninstalling your video drivers and re-installing them...That might help...And what is the name and Model of your monitor ???
D
digik
Resolution can be changed. But, the drop down list doesnot contain the resolution 1600x900. Model of LCD is Samsung Sync Master B2030.
