kool
My printer (F4488) will not print. Orange light keep blinking, and "E" appearing in display. In the HP printer utility it says in status: "Door/Cover is open" and it will not print.Nothing is open and I can't even find ant tabs or sensors to check for malfunction. I think during changing cartidages i broke the lever that is found left side under printer,
Guys from where i can get that new lever?
