Hi guys
Been facing the problem for a while.....my device pocof1 has been discharging fast for a while....the main issue here is that when I play asphalt 9.....after playing 3/4 games it starts to lag a bit and I am using cpu z to monitor temperatures in which the battery remains at 26/27degrees while the CPU cores go upto 44/45.....thats not it.....after reaching below 30% battery.... it shuts down automatically......and if connected to charger then it starts from 0%.....I don't understand is this battery problem or hardware problem.....since battery temperature remains stable.....need help...thnx
