PC problem....please help
neil_dcruz_19
Hey,
I have windows XP SP2 installed on my pc...but lately ive been having some problems and am having a hard time figuring out whether it is a software/harware problem.
The problems I'm facin are:
1. When I start my PC...most of the time it works fine as if nothing is wrong with it...but sometimes randomly it just doesnt start...I mean it does get powered on but I do not get the all OK beep and it keeps restarting and the monitor does not come on.
2.Sometimes the monitor does come on and i get the following message:
Windows NT has found only 0k of low memory. 512k of low memory is required to run Windows NT. You may need to upgrade your computer or run a configuration program provided by the manufacturer.
Can anybody please help me and give me a solution to my problem.
Thanks,
Neil
Mail: neil_dcruz_19@yahoo.co.in
Stalker
check ur power cables first & make sure the ram, pci cards are not loose in their slots.....also chek ur virtual memory
N
neil_dcruz_19
Hey,
Thanks for your reply.
My PC configuration is as follows:
ASUS 845 chipset motherboard 2MB cache
256 MB DDR ram
intel 2.4 GHz processor
sony dvd r/w
DLink wireless lan card
