#include<iostream.h>
#include<conio.h>
void main()
clrscr();
int a[10][10],i,j,k,sp,minr,pos,flag=1,row,col,saddlepoints[10];
cout<<"Enter no of rows :: ";
cin>>row;
cout<<"Enter no of columns :: ";
cin>>col;
cout<<"Enter the contents of the array :: ";
for(i=0;i<row;i++)
for(j=0;j<col;j++)
cin>>a[j];
cout<<"The matrix representation of array is: ";
for(i=0;i<row;i++)
cout<<"\n";
for(j=0;j<col;j++)
cout<<a[j]<<" ";
cout<<endl;
for(i=0;i<row;i++)
flag=1;
sp=a[0],pos=0;
for(j=1;j<col;j++)
if(a[j]<sp)
sp=a[j];
pos=j;
for(k=0;k<row;k++)
if(a[k][pos]>sp)
flag=0;
break;
cout<<"The saddle point of row "<<i+1<<" is "<<sp<<endl;
saddlepoints=sp;
sp=saddlepoints[0];
for (i=1;i<row;i++)
if (sp<saddlepoints)
sp=saddlepoints;
cout<<"The saddle point of matrix is "<<sp<<endl;
getch();
Nah... i just need it to display whether the entered matrix has a saddle point or not and if yes display that number.sakumar79 said:Should the saddle point represent the location of the number (row, column) rather than just the number? In that case, the above program should be tweaked a bit...
Arun
saddlepointa(int a1[10][10],int rowa,int cola)
int big[10],small[10],i,j,max,min;
clrscr();
big[0]=a1[0][0];
for(i=0;i<rowa;i++)
for(j=0;j<cola;j++)
if(a1[j] > big)
big = a1[j];
for(j=0;j<cola;j++)
small[j]=a1[0][j];
for(i=0;i<rowa;i++)
if(a1[j] < small[j])
small[j]=a1[j];
min=big[0];
for(i=0;i<rowa;i++)
if(big < min)
min = big;
max=small[0];
for(j=0;j<cola;j++)
if(small[j] > max)
max = small[j];
if(max==min)
printf("\n\n\n\t\t\tTHE SADDLE POINT IS --> %d ",min);
else
printf("\n\n\n\nNO SADDLE POINT");
getch();
return 0;
#include <iostream.h>
#include <alloc.h>
#include <stdlib.h>
#include <limits.h>
class SaddlePoint
private:
struct spstruct
int value;
int idx;
/*int *imatrix;*/
spstruct *mincol; //LUT of max of each cols.
spstruct *maxrow; //LUT of max of each rows.
int rccount; //Number of rows or cols in the LUTs.
char isLoaded;//Flag to check if the LUTs have been initialized.
int spcount; //Saddle point count.
public:
SaddlePoint()
isLoaded = 0;
spcount = -1;
~SaddlePoint ()
delete[] mincol;
delete[] maxrow;
char LoadMatrix (int *thematrix, int rows, int cols)
/*Do some preliminary checks*/
//Is it a valid row and col value?
if (rows > 0 && cols > 0)
//Is it a square matrix?
if (rows == cols)
//if (sizeof (thematrix) == rows * cols * sizeof(int))
rccount = cols;
//else
// cout<< "Matrix size does not match size params!";
// return (-1);
else
cout<<"Only square matrices (for now)";
return (-1);
isLoaded = 0;
maxrow = new spstruct[rccount];
mincol = new spstruct[rccount];
for (int i = 0; i < rccount; i++)
maxrow[i].value = INT_MIN;
mincol[i].value = INT_MAX;
/*TODO::Allocate space for a local copy of the input matrix
imatrix = (int *)malloc (rccount * 2 * sizeof (int));
int i = 0;
for i = 0 to
/*Find the max from column and min from row
and fill teh LUT*/
int irow, icol;
for (irow = 0; irow < rccount; irow++)
for (icol = 0; icol < rccount; icol++)
if (thematrix[icol + (irow * rccount)] > maxrow[irow].value)
//Record the value and the col index of the value.
maxrow[irow].value = thematrix[(irow * rccount) + icol];
maxrow[irow].idx = icol;
if (thematrix[irow + (icol * rccount)] < mincol[irow].value)
//Record the value and record the row index of the value.
mincol[irow].value = thematrix[irow + (icol * rccount)];
mincol[irow].idx = irow;
/*//Print the LUT for debugging.
cout<< endl<< "This is the matrix and the LUTs:"<< endl;
cout<< "|";
cout<< thematrix [icol + (irow * (rccount))];
if (icol < rccount-1)
cout<< "\t";
cout<< "| |"<< maxrow[irow].value<< "|"<< endl;
cout<< endl<< "|";
cout<< mincol[icol].value;
cout<< "\t";
cout<< "|"<< endl;*/
isLoaded = 1;
return (1);
int SaddlePointPresent ()
if (isLoaded != 1)
/*Load a matrix first using the LoadMatrix() function.*/
spcount = -1;
return (-1);
/*See if there's a saddle point at all
and return the number of saddle points.*/
spcount = 0;
if (mincol[i].value == maxrow[i].value)
spcount++;
return (spcount);
int PrintSaddlePoints ()
if (SaddlePointPresent () == -1)
return (-1);
cout<< endl<< "Found "<< spcount<< " saddle points."<< endl;
if (spcount < 1)
return (0);
/*Now to extract them saddles*/
//int **spoints;
//spoints = malloc(spcount * sizeof (int) * 2);
cout<< mincol[i].value<< " at ("<< maxrow[i].idx<< ", "<<mincol [i].idx<< ")"<< endl;
return (spcount);
};//End of class
void main()
int *imatrix;
int rows = 0, cols = 0;
int irow, icol;
cout<< "\nHow many rows?->";
cin>> rows;
cout<< "How many cols?->";
cin>> cols;
imatrix = new int[rows * cols];
//if ( (imatrix = (int *)malloc (rows * cols * sizeof(int))) == NULL)
if (imatrix == NULL)
cout<< "Not enough memory to allocate buffer\n";
exit (1); /* terminate program if out of memory */
cout<< "\n:Now enter the elements of the matrix:"<< endl;
for (irow = 0; irow < rows; irow++)
for (icol = 0; icol < cols; icol++)
cout<< "("<< irow<< ", "<< icol<< ")-->";
cin>> imatrix [icol + (irow * (cols))];
cout<< endl<< "This is the matrix:"<< endl;
cout<< "|";
cout<< imatrix [icol + (irow * (cols))];
if (icol < cols-1)
cout<<"\t";
cout<< "|"<< endl;
SaddlePoint sp;
if (sp.LoadMatrix (imatrix, rows, cols) == -1)
cout<< "Unable to load the matrix.";
exit (1);
sp.PrintSaddlePoints();
delete[] imatrix;
system ("PAUSE");
