My motherboard is Asus m4n68t -m le v2...Ever since i purchased this motherboard my front panel ports are not working...Back side ports are working fine...I checked with Real tek and VIA HD Audio driver..But none solved..In my System tray it always shows Digital Audio(HDMI)..But my Monitor is connected via VGA not via
HDMI(HD 6670 GPU)...So i thought its the problem with cabinet so i purchased new cabinet..But the problem still exist...
Now i'm fed up and writing here for solution(this might be the last attempt)...I found on Internet that changing HD audio to AC 97 in bios will get front panel audio ports work...But nothing Worked...In device manager I only see Digital audio(HDMI) Under audio and 2 USB controller and 2 root under USB option....
OS is Windows 7
Someone help me over here plz...
OS is Windows 7
