sunandoghosh
Dear Friends,
Need one urgent recommendation.
Want to buy one earphone wired with loud sound.
Primary usage to be able to clearly receive and make calls from laptop for work.
So loud clear sound is only requirement.
I dont understand bass treble etc.
Just want simple clear sound loud.
Pls suggest me good wired earphone which meets this criteria.
Budget is variable but will be comfortable from anywhere from 500 to 1500 rs
Key point is loud volume
Kindly reply asap as my current earphone got crushed below chair and need replacement asap
Thank you
Thank you
