ashu888ashu888
Core i7 (nehalem) Owner
Hey Guys,
There is this wierd problem, Let me get into the specifics first:
Processor: Intel 1st Gen. Core i7-920 (running on stock 2.66 Ghz, no OC done ever)
Motherboard: MSi x58 (lga 1366) pro-E
RAM: Corsair Vengeance 3x4GB (Triple Channel Kit)
PSU: Tagan 1100BZ (1100W)
GPU: MSi N580GTX Twin Frozr-II (1.5GB) with 2xDVI Ports on the GPU
Monitor: Samsung 23" mode: 2233SW
OS: *ahem* version of Win 7 x64 Ultimate
Now, The problem:
1.) (at times) The CPU Seems to be running fine, but the Monitor LED blinks,
It will start fine if I RESET the Battery and Clear the CMOS,
but,
2.) Sometimes even this does not Help, so I have to remove all 3 RAM Sticks and re-insert it again and repeat Step-1 as well and then the PC Boots up fine.
Also,
3.) All nVIDIA Drivers are up-to-date and while playing any game or just surfing, it would all of a sudden restart on me (or worse), just keep on blinking with the CPU Running.
4.) CPU & GPU Temps are normal, Also re-seated the GPU.
Steps taken by me:
a.) Interchanged the end points of the DVI Display cable,
b.) Updated GPU Drivers,
Cheers n e-peace...
Now, The problem:
but,
Also,
Steps taken by me:
Cheers n e-peace...
