Cm 690 II Advanced, Asus P8p67 pro not compatible with Corsair H80?.. Please Help!
Viswanathan
Hi yesterday I purchased Corsair H80 and I today when I tried to install Corsair H80 I am not able to!. Behind the motherboard, to which I should fix the spider like attachment given by corsair, I am not able to do that. Out of 4 Holes, Only 2 holes of motherboard Is visible behind the cabinet and 2 holes are hiding behind the cabinet!
My Cabinet
*s24.postimg.org/ke0x51br9/27032013061.jpg
This is that Spider like attachment I am taking about
*s24.postimg.org/hl7pl0bet/27032013062.jpg
and also the distance between the motherboard and the sheet is very thin.. If I take out the motherboard and install the cooler and reattach it in the cabinet, The spider like attachment is touching the sheet of the cabinet.. Is it a non-conductor of electricity?.. Will it do any harm if I attach this way?.. Please help me out guys...
V
Viswanathan
@ nikilsharma007nikx
What about that spider like attachment touching both motherboard and tat sheet of that cabinet?.. Will it create any problem like short circuit or harm my computer components?..
thats what im saying man they are made up of plastic so no worries ... but still if you are worried cut the metal sheet which is covering the holes !!!!
V
Viswanathan
Thanks but Dude, its no Plastic.. Its made up of some kind of metal!.. That's why I am worried and I have never modded my case before, so, I have no idea how to cut a case?!.. May be using a cutting pliers?..
try testing it with a multi-meter if u have or by a simple circuit to test its conductivity .... :p and yes u cant cut it with cutting pliers ull need a dremel for this task ..
V
Viswanathan
Alright Guys.. Finally Installed the cooler! :) .. I tried cutting out the tray with hacksaw but didnt work out. Fortunately I have a wielding shop near by my home and i asked the guys whether they can cut it, Guess what?!, they said yes! :) .. So i went down with my cabinet and cut out the necessary part and i was able to install all the necessary kits for the cooler.. So after re-installing the motherboard, had to do cable management once again! :( since i removed everything from the cabinet before going to the wielding shop. Ok anyway i tried to took some pics.. So here is the final result..
Cabinet after cutting out the tray
*s16.postimg.org/xezibqyqd/28032013064.jpg
After installing motherboard and the necessary cooler kits
*s16.postimg.org/sk5tdh0et/29032013067.jpg
Before cable management, without Gpu and without the second fan on the radiator
*s16.postimg.org/798997iad/29032013065.jpg
During Real Temp using Prime 95 Sensor test
*s18.postimg.org/ob30rsa61/test_1.jpg
Test results and pls tell me which program to trust! and is the test results good?.. is the temperature good?..
*s18.postimg.org/9gefdm0l5/Which_temp_to_trust.jpg
I Thank everyone from the bottom of my Heart for helping me out!.. Thank you very much. You guys Rock! :)
