Buying advice fan controller with full speed control.
rockfella
Been using this to run 3x140mm Artic fans and it killed system fan port on my mobo. I love my fans, can anyone suggest a decent fan connector + controller. Fan speed control is a must. Don't need ARGB.
Avoid using this type of connecters.
If your cabinet has the 5'' bays, you could try one of those controllers that fit in the bay and run the fans directly from the PSU power?
I haven't used them so I don't have any personal opinion or experience though.
