NOKIA 3230 bluetooth problem, USB HUB etc..
kool
Today i bought bluetooth dongle (Z-BLUE 120) FOR Rs.300 with BLUE SOLEIL software on small
cd. I installed successfully all drivers and software, but why my NOKIA PC SUITE v6.80.22 is not
detecting my phone?? its not working..... At present i'm using file explorer within BLUE
SOLEIL
window for transffering data/files/ringtones/images etc. i've NOKIA 3230.
and also tell me about some bluetooth software for my nokia 3230.
like: ETi FLYCAM, WINAMP CONTROLLER etc...
and also i bought a USB HUB (with 4 input) for Rs.100 but at a time only one device is working
with it, why???
vijay_7287
make sure ur bluetooth modem is enabled
... in the incoming connections ... go to properties
and enable all available checkboxes
A
anarchist
Guest
i think PC suit does not work over BT in 3230. and why you need PC suit with 3230?
if you have to use PC suit, you can use data cable.
jiteshbhimani
Install WINDOWS XP SERVICE PACK 2
and the drivers for the modem will be detected.
And visit the nokia site and get the version of the PC suite suitable for ur phone i.e Nokia_PC_Suite_68_rel_22_eng_web.msi
install it........and follow the instructions......
kool
kool
i've alreday downloaded latest pc suite 4 my 3230 phone! and i've win xp sp 2 .
