i am having a kob115 cabinet and a intel 915 GAV motherboard which has provision for 4 front panel usb and audio but i have no options in my cabinet is there any way to solve this??????
Usually cabinets do have openings for the type of mobos. I also have 915 mobo. But there is a panel which can be pressed and I am able to access the usb ports and audio ports. I have Xtech cabinet.
my mobo supports 2 front usb.
in my case there is space for it, wht i need to buy to connect the mobo for front connectivity.
i mean wht type of connectors?
is my ques. clear ?
is my ques. clear ?
If the cabinet is having provision for front 2 USBs, it should be having the connectors for connecting it to the Mobo. See inside the cabinet. (In my case, it was like that)
