kuldeep bhardwaj
hi guys,
i m facing some probs with my computer from some time.
1.mouse atak-atak(hindi) ke chalta hai.
2.if one application is open then second app. does not work properly & vice-versa.
3.its speed got slow.
i can suggest some alternatives for that. u see them & tell me the best option.
1.i change my heat sink??????(between processor & fan)
2.as my hard disk had fallen once & i've 0-filled that.so should i change that.????????????
3.1nce my fan on motherboard was broken & motherboard was repaired also & then worked fine.but recently some problems persists(as given above>???????????/
so i want all of u 2 give ur precious comments on this topic.
ur views are welcomed.
