TV Tuner Card REMOTE Problem..Urgent help required
achtung
I have got one frontech internal TV tuner card.
I connected it to PCI 2, and installed the driver and the application(TV Plus) to operate it.
Problem is, when I am trying to use the remote control (e.g. power button, channel shift), remote is not working at all.:(
Also can anyone distinguish between the composite mode and cable mode?:confused:
also after connecting the cable line, most of the channels are flickering.:confused:
Please suggest..:confused:
Thanks..
achtung
achtung
Still the Remote is not working...
Tv Tuner model number is Frontech internal JIL 0606
ANY One!!!!! ?????
Plz H..e..l..p :(:(:(
achtung
achtung
Actually I haven't checked that because it is a new one supplied with the tv tuner card itself.
I'll check that and let u know then...
Thnx for the hint :)
vikasg03
If still it is not working then i know the reason. It needed a remote patch. I am also using the same model tv tuner. After installing the remote patch (size only few KB ) , it start working.
If u need that i will send to u
Vikas
aswin1
Hope you have connected the TV remote sensor unit to the proper slot and put it in the front of the PC.
achtung
achtung
Unfortunately I have tried all these... but noo good guys :(
I think only the patch can help me out...
VIKAS.. could you please provide me the patch ?????
Many thanks in advance ...
P.S. my mail id: uttiya.t2008@googlemail.com
patkim
While H/W or S/W failure can not be ruled out, the flicker could simply be due to need of fine tuning. Do check the application and look for fine tuning settings.
achtung
achtung
Hi Vikas,
I had gone through the read me and followed the steps.
1. First ran the unremote.exe
2. then re booted the PC
3. then ran remotemap.exe
But the remote didn't respond. I used two new batteries, just in case.
Any other method of applying the patch??
Please suggest.
Regards
vikasg03
Check your mail, But gmail don't allowed exe, so i am sending you in zipped format.. just remove extra words from extension (ped)
vikas
