System Fan:::: '0' RPM---> Why?
clifford
HI Guys,
Well I'll get straight to the problem.......
Everytime i startup my system I get the following Error before I see the windows login......
Hardware Monitor::::
CPU Vcore : 1.47v
+3.3v : 3.43v
+12.0v :12.40v
-5.50v :(-) 5.44v
CPU Temp :45degree C/ 113 degree Feh
System Fan : 0 RPM------(here's is the problem)
By the side of the above information this part is included::
AGP Voltage :1.56v
+5.0v :5.13v
-12.ov :(-)12.28v
Voltage Bat :3.24v
CPU Fan : 3590 RPM
Verifying DMI Pool Data
Boot From ATAPI CD ROM
Boot From ATAPI CD Rom
Remove disk or Other Media----(well I dont have any disk in drive)
Press Any key to start
Can anyone help me fig. out wat the problem is......
I'll B very greatfull if u help me to solve me da problem.....
thnaking in advance:p
clifford
ranjan2001
Is the fan connected to the motherboard socket???
if not then it wont show it
if it is connected with only 2 wires then again it wont show its rpm
To see the rpm u need a fan with 3 wires & connect it to the mobo.
What configuration are u running & what software are u seeing these temperature data?
shantanu
and if you got the system FAN attached on motherboard also.. and you get a standard Rs.50/- FAN then it wont show speeds.. as it is not having the sensor.. to report speed.. you can get a coolermaster FAN for that.. as local fans do not report speeds..
just go to your bios by pressing DEL at startup.. now got to boot options and set the first boot device to hard disk and disable removable devices as you dont have that... and also search for quick boot option in BIOS and enable it if not enabled.. and save and exit... now your this problem will be solved,, :D
