eureca_eureca
I am facing some problem with my comp ,
some times i get to see no signal on my monitor , some times the problem gets fixed by removing the monitor cable and turning on the monitor and later turn on with cable attached .
few times the same problem got fixed when i tried removing hdd data cable ...so the monitor flashed and showed the " hdd.... " usual message and after connecting the cables back it was fine .
This problem still exists and some times at most urgent situations my pc dosent start up , instead i get to see the very irritating no signal , and to add the pain none of the tricks i mentioned above works then .
And forgot to tell another imp problem when going through the above procedure , this computer turns off soon after turning on and after few secs it turns on again
hope my explanation is clear enough
What could be causing this problem ? ? ?
My sys config is
Abit ip-35 e, C2d e 6750, Xfx 6800 Gt, 320 Gb sata II samsung hdd , 2*1 gb transcend 800 mhz ram .
Please help me fix this , i am very much in need of a sincere machine .
My sys config is
