1. Hey Guest Did you know you can win an Honor 10 phone worth ₹33,000 and an additional ₹70,000 in paytm vouchers, just by replying to some threads and taking part in the discussions happening in the Honor Hub?
    What are you waiting for? Start commenting and start winning! Remember to read the instructions posted here.
    Dismiss Notice
Sony DW-Q120A Problem...
Discussion in 'Hardware Q&A' started by anilthomas26, May 15, 2006.
Thread Status:
  1. anilthomas26
    anilthomas26 New Member
    May 22, 2005
    266
    0
    0
    I bought this new DVD writer..But it doesnt read the files..Its shows an
    I/O Error...(MY OS is XP SP2)...The i connected the drive to my friesnd's PC
    (XP without SP)..Then it worked...
    Please give me a solution
  2. Kniwor
    Kniwor Learner
    Sep 14, 2005
    1,949
    6
    0
    Chicago
    try on another IDE port, another cable....
    as u said it works on friends' pc...
    do other drives work fine on yours
  3. OP
    anilthomas26
    May 22, 2005
    266
    0
    0
    yes the CD Drive works fine........................
  4. Kniwor
    Kniwor Learner
    Sep 14, 2005
    1,949
    6
    0
    Chicago
    then have u trien it on that port/cable on which the CD drive is working...
    also give details of your mobo
  5. OP
    anilthomas26
    May 22, 2005
    266
    0
    0
    thnxxx..the prob was with the cable......i changed it now it is working
    ThnX a lot
  6. Kniwor
    Kniwor Learner
    Sep 14, 2005
    1,949
    6
    0
    Chicago
    when u solve many problems like this it will not take u time to figure out such things.... lol...
Thread Status:
Share This Page
