ashishstillthere
hi guys i have some problems so instead of posting each in different topic i am combining in one only
1.i wana make my start->all programs list look less clutterd
as i wana make some entry in that like dvd and when i click on it.it should contain all the software which i installed for cutting editing and all for dvd.i dont like list of software lying clutters here and there on the basis of when i installed them
2.need tutorial for ms dos.i wana learn it
3.i wana some software or way to save updates of my software coz its very frustating to download them all after fresh installation of window.i just wana know how to save them while downloading or where did they downloaded in my system so i can save them and applied them later on for example antivirus updates
4.i am using total video converter for all my conversion need but i need one converter/format which can be able to play in common cd player or espicially in window media player 9(not in updated version or in vlc media player) if i am not making vcd via nero.i generally wana convert movies from my n 95 which use to shoot in mp4 format
these are the options comes to me when i tried to convert it
*img225.imageshack.us/my.php?image=tvclu6.jpg
*img84.imageshack.us/my.php?image=tvc2op8.jpg
i am confused that which option to choose or is there any software which can convert any format to DAT format
5.i have lot of dvd copied in my system.i wana convert them all to 700 mb size(like most movies are available in website with the name like 1 cd rip or dvd rip)they are of exlent quality with such smoll size(700mb) so i wana make my movie collection like that.for example i have a om shanti om which is of 4.73 gb and i wana make it 700 mb with no loss in quality.plz give me any tutorial for that
is there any other software available for replacement or better than auto gk for making 700 mb size movie
if yes then plz tell me its name.auto gk is very time consuming despite of having 4 gb ram n c2d 2.66
i know very much long post.but still i needa your help
