serious problem
arko
hey everyone!
my OS is WindowsXP. i have a movie file on my hard-disk in the .avi format. whenever i place my cursor on it or right click on it, my system temporarily hangs and an error message come up that reads something like this:
"Memory at <some location> could not be referenced. The memory at <some location> could not be written. Click OK to terminate, Cancel to debug."
when i click on OK, Windows Explorer shuts down and restarts.
but no problem arises when i open the file with a media player to watch the movie.
is there a way to fix this problem? kindly let me know.
thank you.
theraven
thats cuz when building a preview, windows checks the ENTIRE avi file
and if theres an error it hangs
ur gonna have to disable media previews
check the following list , might be helpful for other things as well
Code:
1) Open a command window (Start->Run, type in 'cmd' hit enter)
2) To remove image preview, type and hit enter
regsvr32 /u shimgvw.dll
3) To readd image preview, type and hit enter
regsvr32 shimgvw.dll
4) To remove media preview, type and hit enter
regsvr32 /u shmedia.dll
5) To readd media preview, type and hit enter
regsvr32 shmedia.dll
Credit: *www.tweakxp.com/tweak2123.aspx
alib_i
also check my reply in the following thread
*www.thinkdigit.com/forum/viewtopic.php?t=25319&highlight=avi+preview
theraven's method will entirely disable the media file preview.
The registry edit i've pointed out there will only affect avi files. You can try any of them.
alibi
digitizen
it is because windows uses the avi or divx codec to show the preview everytime you point it . so the system hangs due to the memory build up taken to load the codec . so either disable video preview or be ready for frequent system hang ups
